LED headlight globes
They say fog/day, they don't say driving. You could replace just one and have fog on one side and driving on the other but I wouldn't.
I don't know Shadow, I don't think the technology for LED driving lights is there yet. I do have LEDs in the rear of two of my bikes. I don't know what's the other.
Projector lamps seam to be the thing up front. Just fitted my daughters VW with some.
Thanks -I thought as much - I guess I'll stay with the blue halogens I've been using for the last 5 years. I have to replace them every two years or so, and it's about that time. I saw some other very pricey bulbs the other day that are supposed to look like rainbows through the headlight glass when the bike is switched off, but they were pretty pricey, at around $15 each plus postage. They do have a lifetime guarantee though which is something...........
Headlamp upgrade?
Hi,
Were you looking to upgrade your headlight power?
I recently fitted an HID Bi-xenon kit to my CBR1000F as has Harry_T_Hamster and HenryM, plus others I guess.
These are brilliant at getting you noticed due to the 'white' light and a big improvement for night riding.
Cheers
Rick
Cheers
Rick
A big help is to have them pointing in the right direction.
While sitting on the bike have someone hold a board in front of the front tire and draw a line across it where the light hits it while using the high beam.
Move the board out on a level surface 15-20 ft or 3-5 m. The light should hit the line. If not you need to come up or down. Low beam will fall in place when the high is adjusted.
I had to do this with my bike. The beam was pointed in the dirt.
Shadow, those bulbs you are lookng at make geat camp lights, I use one mounted in a h/d mining spec flood light enclosure(got it cheap) they draw less than .5 of an amp so don't run your batteries flat. They would be useless as headlights, the new 3w and 10w leds are a different story, amazing light output but very expensive, hids are a cheaper option than them at the moment.
on
Shadow put in some mini balast Hids, they really light up no light or very blackened, low viz roads. I would think they would be just the thing in your neck of the Savana. They last a lot longer than those Halogens you are using now so long term would be more cost effective. BTW cheap LEDs suck, the new 10mm 10w+ superbrights that do work, are way too expensive right now, compared to Hids
Dub
