Jet kit opinions
Jet kit opinions
Hey guys and gals, Anyone here have preferances for jets kits on this bike. I've got a 96 that is bone stock except for a two bros slip on. I've found the k&n,factory pro and vance and hines kits. Factory says it comes with the special tool for accessing the fuel mix screw but that's the only advantage i see. Thanks in advance for your advice. Ed
RE: Jet kit opinions
i went with the k&n which is really dynojet, it's a good kit it only has two set ups of the jets (w/stock exhaust and k&n or w/k&n and aftermarket exhaust) i don't now about the vance and hines kit the factory pro is the best kit from what i've heard it has the most selections as far as the jets and set ups go, as for the tool to access the fuel/air screws it should just be a aluminum plug you have to drill out or a tool that looks kind of like a half moon, but all the kits will have what you need even if it doesn't say it's included, because setting your air/fuel is an important part of the kit. so k&n cheapest least amount of jets, factory most expensive but more jets it's your call
ffingers
01-13-2008 10:22 AM
