Indicator/horn/brakelight fuse keeps blowing
Old 09-14-2008, 02:57 PM
hmm's Avatar
hmm
hmm is offline
Default Indicator/horn/brakelight fuse keeps blowing
Hi all, anyone help?
A few weeks ago the horn/brake light/indicator fuse blew after a ride of about ten miles (I was being assessed by the Metropolitan Police on a Bikesafe course at the time!). Replaced the fuse, had lunch (i.e. the bike cooled down for an hour or two) but it blew again later that day. Replaced it again and it's been OK until tonight.
Yesterday I had the tail-light unit off to repair some of the broken plastic tabs, so had to twist out the rear bulb units. This might be relevant!
Tonight I rode about 20 miles and it blew again. Replaced it, tested the indicators, they worked, tested the front brake, it blew again. Replaced it again, tested the indicators again, they worked again, tested the front brake again, it blew again. Had no more 20A fuses so had to ride home without horn/indicators/brake lights.
Anyone suggest what to look for and where to start? Not sure if it blows with the footbrake.
Thanks!
Old 09-14-2008, 03:52 PM
fast1000f's Avatar
Default RE: Indicator/horn/brakelight fuse keeps blowing
well for now i would say its a bad ground or mabye a rubbed wire arcing out? some of the older bikes developed loose grounds after years of vibrating. check the ground for the rectifier, i have a few friends that had that same thing happen over and over. ran a direct wire to the negative from the rectifier, problem solved. no more blown fuses. may or may not be your problem, but somewhere to look. good luck
Old 09-14-2008, 03:57 PM
fast1000f's Avatar
just reread my post, didnt mean to imply that i think its your rectifier, just useing the story as an example that it might be a ground or an arcing wire. again, good luck
Old 09-14-2008, 11:30 PM
Shadow's Avatar
Almost sure you have a dead short in your power wire from brake switch/lever to brake light.
Check the switch first, they can be a bit finicky.....
Old 09-15-2008, 12:13 AM
Shadow's Avatar
Been building bikes forever... Many symptoms we have are the same as some of the bikes I've rebuilt - XJ900, GSX1100E, GPZ900R, XZ400, XJ550, and a few (UGH) offroads. Our old birds aren't much different. Current project is a CB750 Custom, which needs new rings. With the price of spares it's cheaper to buy a complete engine ![:@]
Don't ask me anything about the newer injected and chipped bikes - not a clue !
C'mon Steve, you KNOW you're a WD40 abuser.........
Old 09-15-2008, 12:59 AM
Shadow's Avatar
I'm amazed at the variety of problems that some of our buddies have with the FAT OLD LADIES -
in 70000 K's I've never had to
*adjust my valve clearances
*fiddle with my carbs (just a set of leaky bowl gaskets) BUT I have had
1 stator cover
3 batteries
4 reg/recs
1 set clutch plates
2 camchains
a leaky tank which I hope is now fixed. two part epoxy is great stuff....he he
It seems some bikes have more problems than others. My reg/rec problems were my own fault - dry battery = blown electricals. I think that (like me) some of our bikes are starting to feel their age........(and a lack of maintenance in their past lives)
Y'Know what they say -
You know you're getting old when everything hurts, and what doesn't hurt, doesn't work....!!
I'm glad everything still hurts....he he[&:]
bigroony
05-28-2020 07:21 PM
mrchips
12-04-2011 11:41 AM
bigroony
03-18-2010 02:30 PM
taymax14
07-03-2007 12:12 PM
p01ishedF4i
03-10-2006 06:29 AM
Quick Reply: Indicator/horn/brakelight fuse keeps blowing
