Idles rough & harder to start when warm???
My 91/92 CBR1000F seems to be idling rough after it warms up. Once I've been for a ride I can pull up at lights & wait & it will sound rough & feels like it will stall. Plus once I turn the bike off & try to start it again sometimes it takes a bit to start it.
Through acceleration it is fine, but its just under low revs that its rough.
Any ideas???
Dan
Any ideas???
Dan
RE: Idles rough & harder to start when warm???
Dealing with one of these strange cases on another forum.
Valves, coils, and vapour lock.
When was the last valve adjustment?
Do you have a prime on your bike? If you put the bike on prime for a minute, then hold the throttle WFO will it start more easily?
Then the next question is could you test your own coils... heat does funny things to conductive metals.
It is a very weird problem... and I'm not saying it's any of those three things for sure, but those are some typical starting points.
ditto,too rich,mebbe choke is stuck on a bit or airfilter blocked up,are running on prime perhaps?,mebbe the vacumm bit of the fuel tap has died letting it run like on prime.
only other thing i can think of is the plugs or coils breaking down when hot.
JayBoCC2
06-23-2009 10:23 PM
