Idle Mixture on a 1996
RE: Idle Mixture on a 1996
Nope. Honda/Keihan (sp)? did not do us a favor when they built these carbs. Think recessed bolt. You need a socket to get at the bolt, right? Well, the "bolt" is an actual "D" shaped head brassscrew. Honda and Mac tools have the bit that fits onto the idle mixture screw. Still haven't got the camera working. I've got to get it working and Ill post some pics to help you.
Art
Art
Although the bowl is off on this photo, the idle mixture screw is visible at the lower center. There is a faint red arrow pointing it out. As you can see it has a flat spot on it at about the 8 O'clock position.
[IMG]local://upfiles/10297/69D1E98B26E544F9A3CF8641B950EB2F.jpg[/IMG]
Okay I see that. I'll check with Mac tools and possible the Honda dealer to see if I can come up with one of these tools.
The problem I'm having is low speed hesitation. Off idle up to about 2500 RPM. It seems like a classic lean condition. I was thinking of shimming the needles but since it's only off idle, I thought I'd try fattening up the mixture a bit and seeing if that helps.
Thoughts?
Thoughts?
The carbs that came with my bike have the cross hatch, like a phillips head. My bike came from some where in Europe. The set of used carbs I bought off of ebay (from the US) came with the D shaped screws. I also noticed the needles from the US model are longer, about 1.5 mm. The springs that goon top ofthe needles are longer as well. Trying to make one working set out of these two units is making me crazy. I have the bike running, but it's running like crap.
By any chance does any one know where I can get a brand new set of carbs (euro version)? I'd really appreciate the help.
