how hot does your bike run
ok tell me if anyone elese bike does this
i can ride all day and my bike temp gauge stay about 1/4 way
up as long as i moving but if i stop for 3 or 4 min while it running the temp will go up to 3/4 on the gauge
if you shut it off when the temp is up and then try to
restart it. it sounds like the starter is drag but let it cool off for about 10 mins
and it starts up perfect when it's cold starts right up
if anyone has had this trouble let me know
greymustang
greymustang
RE: how hot does your bike run
Had the same trouble a while back. I installed a switch that I can turn on the fan with when sitting in traffic and whatnot. These 1000cc "more experienced" bikes all do it, and especially the Hondas from my experiences. If you add a switch put a diode in line as to isolate your switch from the battery. Email me if you have any questions on adding a switch. shane_workman@insightbb.com
Mine does exactly the same thing and it drives me nuts. I'm sure the big bore kit doesn't help. I added the prescribed dose of WaterWetter but don't really notice much of a difference.
Who's doing the raind dance out here? [:@] I've had just about enough of this BS.
GM, keep an eye on your mailbox.
Fan switch and diode set up:
1. Buy a vibration resistant, 2 pole switch.
2. One pole of the switch goes straight to your ground side of you battery.
3. The other pole goes into a diode (1N45 should work) and from the diode to the ground side of your factory thermostat switch.
4. Mount your switch in an "easy to get to while riding" spot and you are done.
The diode simply isolates the factory switch from your installed circuit. If you cant get it to work, try turning your diode around as they will only let current and voltage through one way. Also make sure that ground is what triggers your fan. If 12V+ is what triggers it, simply put the first pole to the pos. side of your battery.
Good Luck!!
Good Luck!!
Fan not working
Seems like we all have some problems with our bikes runnning hot. Mine getts really bad when I'm stuck in traffic headed to the Cape during the summer, so I tell me wife I'm forced to creep down the middle. So I just put my exhaust on an now I've got another problem. My bike was in the red today stuck behind a school bus, my fan isn't switching on[:@]. Any idea what might be the problem or did anyone else have this problem? When I get home I will check to see if I blew any fuses. Any feedback is apprciated.
Thx
Thx
I wouldn't say my bike runs hot, the gauge just creeps up a little over half way before the fan comes on. I haven't checked the actual temp. with my Raytek or a themometer and, I'm not so sure the gauge is real accurate. Think about it, how accurate is the Speedo or the gas gauge!? They're all made by the same manufacturer in the same gauge cluster.
