Help! Dad's 1000f stopped charging
My dad's got a 93 CBR1000F with 30k on the clock that has run great until yesterday. It wouldn't start so we charged it for a while and got it started......
With the engine running we checked battery voltage.....it kept going down and down. So the battery is supporting the engine????
He tried to ride it and it died pretty quick. What should I check? Is this a common problem? Thanks.
________
GAY MOVIES
________
GAY MOVIES
RE: Help! Dad's 1000f stopped charging
I've been reading a little and want to test the regulator/rectifier. I searched but didn't come up with a test procedure. Any help is appreciated.
________
Bondage Xxx
________
Bondage Xxx
http://www.electrosport.com/Images/fault_finding.pdf
This should do the trick. Or you could ask Shadow if the poor chap comes down off the ceiling...[:@]
Your Reg/rec could be dead - check the level of water in your battery before going any further, and I think you'll find the thing's probably dry. If so, and you checked it recently, then your regulator is allowing too much current to the battery, and has boiled it dry. Replace the regulator, and the battery's probably shot too after all the excessive loading. See also MANY posts on this issue, and yes, it's a common problem, ESPECIALLY FOR ME[:@][:@]
The manual at
> http://members.iinet.net.au/~cbr/Honda_CBR1000F_Service_Manual.pdf>
or
http://myweb.tiscali.co.uk/midlife/i...ice_Manual.pdf
has the test procedures for reg/recs I think.Download it and see- Hope it works -
I'm off the ceiling, Flogger, just p....ed off !!
The manual at
or
http://www.electrosport.com/technica...ding-guide.php
sorry, seems they are having a problem with their site.
Voltage on your battery with a running engine should be somewhere near 15 volts. Engine off should be around 12. If this isn't the case, your rectifier probably is fried. Pretty common with Honda's
It could also be the alternator. 3 wires should come from the rectifier, and they should measure about 55+ volts AC, or i think 80 in beteen two of these wires. After rebuilding my little sisters GS500 it started failing after a while, after some inspection i discovered she made a mistake while rebuiliding it; the chain was eating away the 3 cables that came from the alternator!
good luck
good luck
