Headlight bulb replacement? "96
That price doesn't sound too bad. Mr. Cycles charges $22.90 + shipping: http://www.mrcycles.com/fiche_section_detail.asp
Remove
1 windscreen
2 inner fairing panels
3 upper fairing inner panel
4 Bruise fingers for an hour or so getting bulbs in and out.
Buy standard car bulbs, and fit adaptor rings for $10 a pair, or cut tabs off std car bulbs and retain with just a spring. Prefer first option, available on e=Bay.
Enjoy !
1 windscreen
Enjoy !
Shadow, we've been here before. You don't need a spring- the stock retainer clip will hold the bulb in place with the tabs cut off just fine. The alternative method to Shadow's number 4 above is to remove the upper fairing (which means you have to remove the lowers too).
