handlebar risers on an 87
hey guys i'm having a bit of difficulty preforming low speed maneuvering with my 87 1000f i was wondering if anyone else had the same issues. if so is it my riding style? would risers for the bars fix or at least help a little? any input is appreciated, as i'm a pretty young rider haven't been at this very long.
thanks fellas |
Slow speed riding issues
Brother, there is help out there with slow speed riding. Try this site www.ridelikeapro.com I have purchased a few of Jerry Paladino's DVDs and VCRs. He teaches slow speed riding on cruisers, but the technique is the same for a sports bike. I use it all the time. Before viewing his videos, I had problems with U-turns, circles, figure 8s and what not. Now, "no sweat G.I." (as the Koreans use to say to me).
I practice his techniques at least once a week during good weather. I use tennis balls that I cut in half for cones. Little half tennis balls are cheap, durable and a hacksaw cuts them in half in a few strokes. By the way, you can use a lot of his slow speed techniques on the twisties, but you had better be real good and be going real slow! :rolleyes: Also, get the video series "Street Smarts." There are 3 videos in that series. They teach you street riding techniques and racers give their opinions on street riding. Although most classes teach the use of both brakes, I only use the rear brake at parking lot speeds. Since I also drive a car, my right foot sometimes is too heavy for a motorcycle rear brake at high speeds (it is an old man brain thing I guess!). It is difficult to separate rear braking in a panic situation, so I stay away from the rear brake at speeds faster than parking lot speeds. I use the rear brake only in parking lot speed situations. Why? Using the front brake at slow speeds will make the bike turn-in and dump you. The front end tends to "pogo" with the use of the front brake at slow speeds and that will help dump you to the inside. Use the front brake at faster speeds and rear brake in the parking lots. That is why I practice, so that my mind knows what the heck is the right thing to do in a panic or in a U-turn. The Street Smarts series can be Googled for a place to buy them. Hope this helps Brother. :) |
Is your problem regarding the steering lock range or just the bar position at low speed mate?
Most of the times where I have nearly gone ass over have been when maneuvering at low speed turning and running out of lock:eek: they go and try to fall over very easily on full lock unless you use a little power to keep them upright...small jabs on the throttle will keep them turning on full lock, although I suggest that you avoid turning her on the stops unless you have both feet down:D or have at least practiced it allot !! I hate the both feet down dragging look myself and I try never to do it unless I am almost stopped... Us older riders are meant to be experts:rolleyes: so I like to look like I am not scared or worried by my old girl at low speed .. feet up and balance or at least I try to where ever possible.. At lights ect , I have always practiced the balance while stopped till the last second thing to improve my balance control..... Having said all that , you may find that slightly raised bars might help you with this issue ... I know some of the guys have changed the bars, .. but me , I love the look of the std ones too much to go frigging with them ... |
Look at Tony Dillworth's bike - http://foodman123.com/cbr.htm
He has changed his bars. I think they look cr..p but to each his own. Pacojoseph has a neat set of adjustable bars on his. Fit a set of VFR750 bars - will raise the ride height about 11/2 inches. None of this will change the fact that Hurricanes have a BIG turning circle and are heavy at slow speed. Practice, practice, as Nevada says. |
thanks
hey thanks a lot fellas. i'm confident that with practice i can handle it pretty easily. you're right shadow, they don't look near as good. i think i'll just keep them they way they are and just get better at low speed riding. just waiting for my next off day now....
I have a set of adjustable bars (Telefix Profi bars) on my bike, as Shadow says, but I certainly didn't get them for low speed manuverability reasons- though they may help a bit in that regard. As far as bar risers are concerned, the only ones I know of for our bikes are the Gen Mars. You can save yourself the $100 for the Gen Mars (which simply consist of spacers that go on the fork tubes) by raising your bars up on the fork tubes about 3/4 inch. This will give you the same effect as the Gen Mars without the expense. See if it helps any.
1 Attachment(s)
Ok, you guys beat me to the punch with the last two posts and with Shadows fixing his link so I could see what he was talking about. My bars are regular clip-ons that can be adjusted up or down simply by loosening one hex bolt in each bar and don't look that much different from stock.
| All times are GMT -5. The time now is 07:26 AM. |
