Handlebar end weights
Hi,
My CBR1000F has these cheap alloy bar ends fitted.
On the ride back home at certain speeds and revs i noticed a buzzing vibration through the handlebars. Would these light aftermarket bar ends be causing this and would fitting heavier bar end weights like the original ones smooth this vibration out?
Cheers
Cheers
I would bet. I installed vfr bars on mine and the weights were mounted differently I believe, anyway I rode the bike with out them and at certain rpms the bars buzzed bad, installed heavy (stock )bar ends, gone.
Cheers for the input - i think i will replace the current ones with heavier original (or similar) weight in the not too distant future and see if that smooths things out.
youbarred: on my old '95 model i had alloy aftermarket bar ends and didn't notice any vibration either......
I just put some heavy bar end weights on my Blackbird. I got then from JAWS in England who does Blackbird aftermarket parts. I'm going to get a set for the 1000F as well.
Jaws Motorcycles and Motorcycle parts supplys for the Blackbird
I will look into ordering a set - interesting to see that jaws also do the longer "extra heavy" bar ends.
I did the balancer shaft adjustment the other day and that seems to have sorted the vibration a lot compared to what it was but will still get heavier bar ends at some stage like the bike was meant to have.
