good 1st bike?
#21
the way most hydraulic clutches work is that pressure in the system (from you pulling the handle/stepping on the clutch) applies pressure against the clutch springs, giving slack for the disc(s) to disengage.. Air in the system will cause cushiness, and if anything, will cause the clutch to not disengage... unless there's some *really* strange system on the CBR, this should still be true
#22
#24
Ok. Clutch plates shouldn't be destroyed like in one instant moment, so let's hope you can still ride it until you get those new parts.
If I remember right, your brake fluids were in pretty bad shape and needed to be replaced? So from that view it's not impossible that clutch fluids could need replacement too. But just now this is still just guessing what is causing that slipping. I'm now more than ever waiting to hear how worn your current clutch plates are, hoping it will solve this mystery.
#25
Yes I must change the clutch fluid, it is not better than the bad brake fluid which was sorted out by hints from this site. But I almost refuse to see any reason at all that old clutch fluid would cause clutch slipping, concidering the fluid is not under preassure when the clutch slips. Furthermore, the clutch fluid is probably as good or bad as it is independent of if the engine transmission temperature. It is isolated from the engine oil and not even on the same side of the engine. I will however not take deadly poision on my homebreewed theory since Honda, according to mikekop, refer to air as a possible cause to clutch slippage.
I have another bike to use if I have to park this one for a while, but I try not to get to much miles on the other one for ordinary transportations.
Thanks Dad for convincing me about faulty clutch.
#26
Hi jreelo4
Yes a CBR1000F is a perfect bike for a beginner! it is fast enough for a beginner and it handles well with the right tires and suspension set up.
The dual braking system should keep you out of trouble and the riding position is very comfortable, please don’t pay any attention what people say about it being heavy they are comparing it to a modern 600 and the bike we are talking about is a 135BHP 10 year old beast.
I find that my bike is very forgiving and it gives me feedback whether it will comply with the angles/corner.
There is a inherent danger of riding any bike and yes the rider is more vunerable when they are short on experience but we all gota learn sometime, my advice is give yourself time and space when in traffic and watch what the other road users are doing and where they might go and note if they have seen you, don’t wheele or brake hard mid corner or lean it to far in the wet.
Stay Safe
Jim
Stay Safe
Jim
#28
Well, It is my first bike to own; but I drove a 100cc dirt bike when I was little then I started driving my dad's 82 cb750 custom. So I was used to something heavy. However this bike will run circles around dads. I won't dare follow my buddy into the curves with his 02 gsxr 600 though, but it hauls me and my girlfriend real well.
#29
Does anyone here agree that a rider's size and weight should be considered when choosing a starter bike?
I'm 6'2" and 215lbs. I ride with a guy who has a '90 1000F (mine's a '95) and he's around 5'7" and 140lbs. There is a noticable difference in the way we handle our bikes. He can't back his up the incline of the driveway into the garage, and I can pull mine around with ease. (well, relative ease : )
#30
