Fuel tank clean up
Fuel tank clean up
Im planning to drain the tank from fuel, is there any kind of solvent I could use after draining the fuel for clean up? Also the insulation under the tank is really dirty and in bad shape. Is it safe to take it off completely? I seen tanks on ebay that don’t have it but the tank also sits on the engine with probably an inch of space. Will there be any change in performance if gas changes temperature? Thanks
Either replace with new material or refit the old one.....if you discard it, at high temperatures you may have fuel atomisation, at which point the bike won't run. In extremes the fuel could boil in the tank - not to be recommended................you could make a new one out of a space blanket and a woolen rug or some carpet underfelt.........
Guest
Posts: n/a
Kopi Ko
10-01-2019 08:29 AM
Mattson
How-To: Mechanical
06-20-2013 03:44 PM
