Front Suspension Concerns
Guest
Posts: n/a
No worries ...I move you mate
Red red whine ...lol
http://www.youtube.com/watch?v=doNUGq7UTiQ
BTW - most of the guys run them slightly raised above the clamps .. I cm sounds about the same as mine ...
A few of the shorter guys actually lower the CBR by letting them come through even further ...
Don't you have to have them high enough for the handle bars to fit on?
But now that we are talking about it, I'm guessing lowering the front end just that much would have any effect on the handling, but if you did it more, what would be happing to the handling if it would ever get noticable.
i.e. might it reduce the low speed tipsies by lowering the center of gravity? Other than that rake and trail would stay the same, huh?
There is a retaining ring that fits into a grove that is cut just below the tube cap. You can loosen the triple clamps and let the tubes drop until the retaining ring contacts the clip-on. That is how mine are adjusted.
You can see the retaining ring in the photo supplied by Shadow. If you look at the left fork tube on the left you can see it at 4-0'clock just above the clip-on. It is hard to see because it is small in diameter.
