Front sprocket help asap
Took off the old sprocket, before loosening, found slop in the gear side to side. It actually was loose and the bolt was very tight.
I have the new sprocket on and the same thing is happening. Is there a small amount of side to side play built into the design? I wonder id this is the correct washer? Maybe the right one has a cone shape or shoulder to press against the gear to stop the rocking? I dont want to close her up without knowing this info, thanks as always guys!
bowtieboy42
F2 Tech
07-10-2012 03:53 PM
kreush33
05-21-2006 12:28 AM
