Front fork air pressure
For those who owns 1987-88 , how much air pressure do you load in the forks?
The manual recommends between 0 and 6 psi.
here is an old thread on the subject Carl ..:D https://cbrforum.com/forum/showthrea...ht=front+forks |
Hi Classic
i am aware of this but i heard some owner go above this and was wondering whom does and how it feels mine is at 4 psi. |
Sorry ....
Mine is 89-90 model so she has no air.. I have read on other forums about peeps blowing seals with higher than recommended air pressures :rolleyes: |
Thanks!
I prefere to put no more than 3 psi. & should be no problem with liking oil from the sealing
Carl, I suggest you loosing 6 pounds = 2.7Kgs.
It is healthier too. |
red baron how much pressure do you keep in your fork?
0 psi, I now have upgraded Work Performance springs, but even before, I had 0 psi on them.
