front end wobble when no hands....
I had to adjust my helmet was doin about 30mph, and cautiously took my hands off the bars.. it was fine then started to wobble my bars it scared me I've had tank slap on a dirtbike and it wasn't fun lol does fork seals make it do that or front tire? I'm putting new tires on in a couple weeks michilen pilot road ct2...
Thanks fellas
Thanks fellas
I had the same issue last year. bike felt smooth while riding but if you removed your hands from about 55 mph on down you would get a slight shake or wobble. i got new tire because they were needed anyway and had the balance rechecked at a different shop cause i thought the original shop may not have secured the weights or something like that. I aligned the rear wheel using the rear sprocket , the chain and a 18 inch straight edge. that helped but only very slightly. I replaced the wheel bearings on advise of a motorcycle mechanic here and it helped a little more. Finally replaced the head stem bearings and voila no more wobble. I would check the head stem bearings first. The other symptom was under hard breaking i would feel a click once the bike stopped. Turns out that clock was the head stem bearings.
I would suspect either tire out of balance or as said, steering stem bearings. If the bike is older, and a lot of wheelies, they wear out. Not sure your model, but a lot of bikes use ball-bearings in the stem. When/if you replace them, go to roller-bearings. It will be the only time you do the job then. If the wear is excessive, you can check them out by lifting the front of the bike, grab the tubes and pull straight forward and back. If you see ANY movement around the triple tree/ stem they need to be replaced.
