fork seals leaking...
When i come in the garage today both my fork seals was leaking....****...tried the easy way out and lifted the dustseal and locking spring... added 9 kgm of airpressure to the fork and the seal just slided up...horray...take of the frontwheel and loosen the forks tomorrow-slide them down and take off the seals put new on and put it together...did not have to dissensembel the whole legs...
RE: fork seals leaking...
i dont have a camera.... but its quite easy just add airpressure to fillervalve at top of leg after removing dustseal and locking spring....in a minute or two the seal slides up slowly by the pressure of oil seeping thru the fork tube bushing...but you need between 8-10kgm of pressure..after the seal is free- bleed out the pressure so you dont spill all the oil...
