Fork oil level - Is the manual spec per fork?
Will try to find my manual and get back to you , as according to the Haynes manual you should also measure oil level from the top of the forks .
Can't remember off hand what the measurement is , but as you don't know how much oil you have in there now this may be the best way forward without draining the oil and starting again .
Also if you didn't pump the fork pistons there may be air in there.
on
1 Post
if you over fill a little you can then use the syringe to draw fluid out - when it suck air you have the right amount.
You dont actually have to have the EXACT amount - you can play around a bit to give yourself a firmer ride etc - but using the syringe method will give you a consistant amount over both forks - with is what you are really after
Fork oil levels measured from top of tube with fork spring removed and leg fully compressed .
May just be easier to add oil a little at a time by trial and error untill you get the 'feel' you want from the front end otherwise you may as well whip 'em off and start the oil filling process from scratch.
Let us know how you get on.
- 600 models..........................120mm(4.7in)
- 1000h/j models.....................148mm(5.8in)
- 1000K models onward.............172mm(6.8in)
I used a little bottle I saved from some 2-stroker oil, it has graduations on it for ounces (up to 7 oz). I know I have 14.0 +/- 0.1 oz in each fork based on that bottle. I pumped it quite a few times when I refilled them yesterday...on the center stand with a big strap on the handle bars to a cross beam rocking her back and forth On the cruise to work on the freeway this morning, the front felt great over the nasty michigan bumps but the rear is almost knocking me off the seat (although I was cruising 75-80 mph, 125kph). Will have to start tuning the rear....
