ever pulled your front tire up?
Old 09-09-2008, 08:47 PM
fast1000f's Avatar
Default ever pulled your front tire up?
whether on purpose or by accident, ever get the front tire off the ground on these 1000's? I was suprised with my 95'. kinda scary, weighs 987lbs. talk to me
Old 09-09-2008, 09:31 PM
Shadow's Avatar
Default RE: ever pulled your front tire up?
Only once with the 17/42 gearing. Bike is nose heavy, but will leave a good black stripe if you push it....[X(]
Old 09-09-2008, 10:09 PM
MarkR's Avatar
So Shodow1, your are saying that the back won't lift
Old 09-09-2008, 11:15 PM
Honda_Hurricane's Avatar
There are no problem lifting the -87/88 model.
With stock 17/42 gearing (as in my avatar): Just get it into the right rev, release the throttle and quickly give it full throttle again and the front will rise. Or if you want it smoother, use the clutch in lower rev.
With 17/45 (as I use nowadays, god modification): Just turn your right hand and wait. In 1:st gear the front ALWAYS rises with maximum acceleration.
Old 09-09-2008, 11:17 PM
Ooops! I double posted. I remove this.
Old 09-10-2008, 12:32 AM
Shadow's Avatar
Hey MarkR - Who's SHODOW1 ?
Nope - doing endo's on a 1000F isn't on my wish list !
Fast1000F -987lbs ??? (Bike 550, you, 437 ??) Scary thought.............[X(]
Old 09-10-2008, 04:07 AM
MarkR's Avatar
Darn, my keyboard is playing up again
Old 09-10-2008, 05:40 AM
bicklebok's Avatar
Mine came up speedshifting into 2nd gear last weekend. Wasnt enough to make me liftthe throttle though. Still, I was impressed!! Im one tooth lower on the front.
Old 09-10-2008, 09:19 AM
boink1079's Avatar
Clutch, clutch, clutch, clutch, more clutch controlAND ***** - thats all it takes.
I have standard gearing, second gear, revs around 5000, finger the clutch while posting revs around 9-10,000 and be brave it is heavy, but balanced. Have fun.
Old 09-10-2008, 03:54 PM
MarkR's Avatar
Nearly every gear change is a speed change on the way up, with a blip on the way down - sounds cool
Quick Reply: ever pulled your front tire up?
