Coolant and Temps
Noticed that my new to me 90 model has the fan switch mod that I can turn on anytime via the switch. Cruising around in 70 degree temps I noticed the temp starting to climb. Since it is only a gauge needle, I have no idea of actual temps, but don't like the idea of her getting hot on a 70 degree day. Anyone running engine ice in their scooter? Any improvement over the stock coolant?
Maybe a new thermostat and coolant is in her future? |
How high is it climbing? Mine will typically get up to 3/4 when I'm stuck in traffic but it's fine - fan kicks on and it doesn't over heat. I run Engine Ice too.
Never over heated, just climbs sitting still. I don't have a history with the old gal so I'm not sure what is normal.
my 1990 goes to 5/8 in traffic in hot weather and the fan kicks on never a problem
my 1993 went to 7/8 in traffic in hot weather and that pissed me off so I put the manual switch in - since it's my highway commuter most of the time anyhow I don't use the switch hardly ever but it's there should I have to my 87 is same as the 1990 - predictable - no issues Meh suppose I could have easily installed a new lower temp thermo switch in the rad of the 93 - must do that sometime :) |
From the sound of it, I think mine is ok then.
Originally Posted by thedrewski86
(Post 1253209)
unless you ride a 20 mile daily commute at 3mph - I'd say yeah :D - the bike will
stay cool at anything over 15mph except for maybe 90 degree plus weather then a good 35mph + will be needed |
I was thinking about this same situation tonight after being stuck in heavy traffic, two up, and watching the temp gauge get very close to red. Moment I hit the highway it went down to 1/3 and stayed there. Fitting a lower temp switch is one option, but I was thinking along the lines of a higher efficiency fan. Has anyone fiddled with this idea. I'm sure modern fans draw less power and produce more air flow than these ones do.
https://cbrforum.com/forum/cbr-1000f...2-003-a-87951/
and if you were to go with the more recent fans - true they are more efficient but for a hurricane I think you'd need a tandem setup - this I know from messing with Kawasaki Fans the by product of efficiency is less air being blown |
Yeah, these bikes are a bit unnerving the first few times you see the needle damn near in the red. You get used to it after like 7 years...... sort-of. :D
Originally Posted by Sprock
(Post 1254745)
