Connecting to vacuum take of points 1995 model help
Guys I have a 1995 model that has the vacuum take of points under the carbs for the sync for gadges to connect 2. My question is I can get to 3 of the take of points to connect to but the number 3 rubber block off point is a no no for me have big hands lol no way I can get anywhere near it. What do you guys use to get at this number 3 one on the 95 model. . I have carb tune gadges from years ago when I had the 1991 cbr 1000f that had the vacuum take of points at top of each carb to handy back then |
You can try using a pair of long needle nose pliars. That might get you what you need
Thanks I will have to buy some and try thanks for the help
Get bent needle nose pliers. They will be a big help.
Cheers guys can I ask can the original tank be used when ballancing carbs as it needs the vacuum to let fuel in ?. Or do I use a temporary fuel supply setup
It is up to you. Some people rig up their tanks others use a temporary tank. i prefer a secondary tank but it is an added cost
If you have a vacuum bleeder it will work with a little pumping now and then.
