Clutch slave rod
Old May 12, 2023 | 02:24 AM
KnightRider212's Avatar
Default Clutch slave rod
Hello so i seem to have a problem on my 93 cbr1000f..
the rod that connects to the clutch slave cylinder is not going in all the way,it is almost like its too long..(i took it out before) Now the bike is in nuetral..is that normal? Its not letting me connect the plastic speedometer adapter to the sprocket bolt.maybe im doing something wrong or something is missing?
Old May 12, 2023 | 08:55 AM
rockpool's Avatar
Hard to tell without the sprocket cover on - The shaft goes through the cover etc - you can remove it by only removing the slave cylinder. I would pull it out, reinstall everything except the clutch slave cylinder, and worry about it then.
Also- some purple degreaser in your future? ;-)
Old May 12, 2023 | 08:56 AM
rockpool's Avatar
btw - https://www.hondapartshouse.com/oemp...f4d/water-pump
Old May 18, 2023 | 06:18 PM
Thanks a bunch rockpool,it seems to be fitting in nicely now
FredFlinstone
May 7, 2022 02:32 PM
RyanEricW
Sep 8, 2010 11:34 AM
FRM
Nov 2, 2009 10:21 AM
CBR1000fking
Sep 22, 2008 02:39 PM
fusor
Jun 2, 2006 12:48 AM
