clutch adjustment
If it's like most bikes, you can adjust the slack at either end of the cable.
I usually back off the handle bar end, then take most of the slack from the
lever at the clutch housing. I do final slack adjustment (usually 1/4 to 3/8")
of take-up at the bar lever.
It's a good idea to use a cable-luber and spray-lube about every 500-1000 miles.
That keeps the "gorilla grip" from sneaking up on you.
Ern
Ern
Cheers, Steve
The lever goes all the way out before it bites , but doesnt seem to slip , will try a fluid flush and see what happens . Or like someone said maybe adjustable levers , my gsx1400 felt different
If not for the slop in the lever it would grab instantly due to the hydraulic system being self adjusting.
Sounds like your good to go.
It can't do any harm to change the fluid, especially if it's really dark, just bleed the line as you would do with the brakes.
Let us know the results, always good for future reference.
