Choke stalls 96 hurricane
Old 11-17-2018, 12:09 AM
Jsceen's Avatar
Default Choke stalls 96 hurricane
Hi all,
my 96 was running perfect. I parked it for a month and now it wonít start or run when I use the choke. Since it ran perfect before I donít understand why it does this. It starts up cold without the choke if I give some throttle but not if I pull the choke like I always used to when it was cold.
Thanks for input guys.
Old 11-20-2018, 10:26 AM
tentacleslap's Avatar
That's odd. Usually if there's trouble starting it's the opposite problem (ie will idle on choke but not without)
It sounds like it's running, so maybe not worth going to great lengths to diagnose it, but next time you're doing work on it I'd check out the air filter and make sure you're using fresh gas. To confirm rich you could pull the plugs, but if it runs fine I wouldn't bother
My daily is an 82 goldwing and it never needs the choke. Even on crisp mornings
Old 11-20-2018, 07:30 PM
It is odd. If I had to guess I would say the choke circuit is clogged. The good news is that is a pretty easy thing to clean.
mbrown22
11-23-2010 10:37 AM
dalves11
09-22-2010 04:47 PM
Destinmatt
02-02-2009 09:59 PM
serge1284
07-19-2008 02:31 PM
Cru
09-12-2007 03:26 AM
Quick Reply: Choke stalls 96 hurricane
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
