Carb help needed
Old 06-24-2018, 08:17 PM
Sporty982000's Avatar
Default Carb help needed
My 1990, cbr1000f,
I did a stage 2 jet kit 2 years ago, 4 into 1 exhaust, uni air filter, cleaned, oiled, new plugs.
below 3,000, rpm, bogs bad, hardly takes off. Or dies. A real peta, taking off. From dead stop.
idles fine, above 3,000, runs fine.
what should my a/f, screws be at, ? What should I look at ? To resolve issue.
Old 06-25-2018, 04:58 AM
TimBucTwo's Avatar
Did you replace the copper seals when the 4-1 was installed? Sounds like a head pipe leak.
Also did you turn the pilot jets out 2 1/2 turns after re-jetting?
Old 06-25-2018, 05:04 AM
No, bike came with the 4 into 1. 3 years ago. I have felt no air leaks there, I have checked that area, don't think this is the issue.
Old 06-25-2018, 05:06 AM
I think there at 3.5, that was two years ago.
Old 06-26-2018, 08:59 AM
TimBucTwo's Avatar
You may not feel any leaking head pipe. The 4-1 works by creating a low pressure behind the high pressure wave of a different pipe. This low pressure helps pull the next high pressure wave along. The low pressure in the head pipe can suck outside air into the head pipe where it meets the engine if not sealed properly. The outside air, when it collides with the hot spent exhaust gas, expands many times its volume. The expanded air blocks the head pipe like stuffing a potato in the end of the pipe. At higher RPM, with a small leak, the air doesn't have enough time to get sucked in. The problem is not so noticeable with a more restricted (stock) system where there is some back pressure stopping outside air from entering. With a 4-1, you got to get them sealed properly.
From your description, you have signs of a head to engine leak. You can try to tighten them down more evenly and see if that helps.
Here is a LINK the the parts you need. If you pull the radiator back to get to the head pipe nuts you might as well replace the seals. They are not much money. I didn't have to look up the part number as I have 4 in hand while typing. I suspect I have a very small leak myself as I have a slight stumble while taking off from a dead stop only on hot days when the fan is running. Last month I had a similar problem with a bike I'm rebuilding. I put a 2-1 on and it had a hard time coming off idle but would rev. I thought I had them on even but had to even them out. Now its OK.
You have to go by feel. Tighten them down by hand, then use a ratchet slowly 'til you feel resistance on one. Then turn the other until you feel the same resistance. Then tighten them down evenly with the same feel.
If you find the problem, please report back. I'm putting money on head pipe seal.
Old 06-26-2018, 05:13 PM
Tim, I may take a look into this, I appreciate the info, it be a week before I have tgst kind of time.
Magicsack
07-20-2018 05:25 PM
sccbr600
06-02-2012 05:48 PM
JankCibberf2
05-23-2011 08:22 PM
LJ Harp
11-04-2010 06:58 AM
codsters1
05-01-2010 08:40 AM
Quick Reply: Carb help needed
