Broken starter chain
Yup !
Watch this and you'll know.....................
http://www.stu.co.nz/cbr1000fix/
https://cbrforum.com/forum/showthrea...ad.php?t=87653
jinglezdj, i had same problem when i got my bike. i ended up having to change both the starter clutch and the dampner thats on the alternator shaft. i had to take her apart like 10 times to figure that one out. if your alternator shaft is turning and the motor is not turning i would suggest you try that part. Get the service manual and look in it, its in section 10-16 part number 18 on the diagram. if if your good and have a small pick you can get it off with out seperating the crankcase. took me a few hours to figure that out, i really didnt want to completly disassemble her.
Well I managed to follow the guide that was provided by another chap who had the same problems as me, managed to get the damper out and check it out. I can turn it one way but not the other even with some force, so I think that is ok. I then checked the starter clutch thingy and again the same with this. So I guess its all ok?? I'll re-assemble again tomorrow and give the starter another try, but maybe it is the starter motor after all. What would you guys say?
Thanks
Thanks
NOP
You can't test them just by trying to turn by hand. It's probably not the starter clutch, but more likely to be the starter damper. Read the writeups on this - basicly you need to clean the plates and refit them - I fitted an extra spring which will work for a while, but I think eventually I'll have to buy a complete new one.(you can't buy the parts separately as far as I know) Price around $120 from www.mrcycles.com
This may help you..................one of many threads on this issue
https://cbrforum.com/forum/showthrea...starter+clutch
What now
This is an update as i promised to the starter chain repair. Engine is out and case is split,I found that the tensioner for the starter chain was broken when I took the case apart so that is ordered and the new chain is on the crank. But, I have one small problem I cannot for the life of me figure out how to get the chain back on the alternator shaft. The manual is no help If any of you guys know the answer I would really appreciate it if you would tell me too. Here are some pictures to go along with the story.
If you read the original article bt Stu - that tells you to remove the stator, remove the damper unit, and then angle the damper unit and "massage" the chain on.
I'm sure there must be another way with the engine stripped, especially as you are replacing the chain tensioner. Sorry I can't be more helpful..............
Guest
Posts: n/a
I know it was working for you Pete ...
Will someone else try it and tell me if its working for you ?
Gawd ...I still get page not found when using that link Pete ...
