Bent brake lever ... PICS ADDED!!
RE: Bent brake lever ...
Ouch, that does not look what one want on a nice bike. If it can be of any support, I dropped my Bird a couple of weeks ago and got similar damage. It is already forgotten :-)
Four years ago I layed my almost brand newSuzuki hard on side on track. Not a single fairing, the gas tank or the exhaust survived. Today it looks better than new; I replaced the ugly stock grey colour with new blue/white/black parts and now it looks the way a GSX R should. It hurts some in the wallet but it is just to be cheapfor some timeand then it will be no cost at all... The cracked fairing can probably be soldered from the inside and then put a thin line of clear warnish on the outside to secure the paint. The mufflers would have been replaced by a full 4-2-1 system anyway, right ?
ORIGINAL: R1000
Thank you ... I can't forget this I just can't lol .. the bike has been like new for ten years and I go and drop it ahhh!! ..
I have a pic the brake lever now I can't find my camera lead ... I may end up buying a new fairing in the end .. I am just so fussy like that ..also by the time I factor in price of repair and new paint and decals it's often as cheap and easier to buy a new panel :-)
Jules
The problem with aluminum is that you can’t see by eye how hot it is getting when you are heating it.
Years ago when I was I high school, I had a road bike that I converted to off road. Every time I dropped it I would break a lever. In the school shop we had molding sand (green sand), a small furnace and some aluminum stock. I used a stock lever as a mold and poured my own levers. Looking in the furnace the aluminum would just sit there and with out any advanced warning it would suddenly drop into a liquid pool in the ladle.
If you elect to bend it, I would put it in a vice. If you try bending it mounted to the bike you risk breaking something else.
Remove from the bike, place in a vice, put a pipe over the end after heating it, as Dean0 says until the soap goes black, and then gently work it back to its original position in small increments. I've done it a similar way, and whilst not perfect, it worked fine..
ORIGINAL: Juliet
Here is my bent lever ... so what do you guys think??
Jules
Jules
[IMG]local://upfiles/4562/F63807C940474B1C8C86860B0707FE64.jpg[/IMG]
