battery water
battery water
My '95 is running out of battery water. When I top it up, it still manages to hold the charge so it's not a big problem and I suppose it's prolly due for a new battery. Might get a sealed maintenance free one.
Is there anything I should check to see if it's a symtom of a different problem?
on
RE: battery water
ORIGINAL: Triangle
If you need to fill battery water more oftne than normal (maybe once per year) and it is not leaking, it might be a problem with the regulator/rectifier. Check the voltage at the battery with engine running at different revs. The voltage should not be more than about 14 Volts. Maintenance free batterys are real fine, I have that on both bikes and it feels good knowing there is not a lot of acid fog spraying around.
Edit: There was already an ingoing answer when I was writing mine, sorry.
f4izombie
07-04-2011 11:08 PM
jharbinson
12-31-2009 09:23 AM
cb2cbr
03-08-2007 11:20 AM
