Battery not getting gharged
Old 07-12-2008, 06:07 AM
keego's Avatar
Default Battery not getting gharged
There is no charge going into the battery, can I fix this or is it too complicated. I put avolt meter on the battery and reved up the engine but the voltage does not increase, the voltage dropes at the rate of .5 of a volt every 3 minutes.
Old 07-12-2008, 06:28 AM
keego's Avatar
Default RE: Battery not getting gharged
I forgot to mention I have replaced the rectifier.
Old 07-12-2008, 08:17 AM
malbojah's Avatar
time to check the alternator wiring, You can check it at the connection on the rectifier
Old 07-12-2008, 07:01 PM
keego's Avatar
I have a Haynes repair manual so I will check the system according to their instructions. can someone tell why the bike still runs if I keep the revs high enough when the batter is flat ?
Old 07-12-2008, 11:37 PM
Naga_Thai's Avatar
Follow this chart to dertermine th exact problem - don't try to second guess - follow the chart.... it works!
Old 07-12-2008, 11:42 PM
Naga_Thai's Avatar
Jim - Follow this chart to dertermine th exact problem - don't try to second guess - follow the chart.... it works!
http://www.electrosport.com/technica...ng-diagram.pdf
__________________________________________________ ________
Old 07-13-2008, 04:55 PM
MarkR's Avatar
I have the same problem.
Went for a 200km ride yesterday and brokedown 20-metres from the end point
The wiring near the rectifier looks l-i-k-e crap, will have to replace all the connectors
I am also going to make a circuit that warns me of low voltage.
Old 07-13-2008, 05:07 PM
MarkR's Avatar
When are they going to fix the bloody posting, you have to play, find the hidden SQLphase words to get the post to work
Old 07-14-2008, 02:18 AM
keego's Avatar
markr, the connector on my rectifier was all burned, the bike shop wiered in a second had rectifier but that has not fix my problem.
Old 07-14-2008, 03:46 AM
Shadow's Avatar
Second r/r may also be fried.
Check charge rate above 3000RPM
Maybe stator is also u/s
See previous posts on this issue
Quick Reply: Battery not getting gharged
