Battery loses charge when it rains
Old Jun 22, 2009 | 05:34 AM
Oscar Foxtrot's Avatar
Default Battery loses charge when it rains
I bought an '89 1000F a few months back. Has anyone else had this issue: my battery seems to lose charge when I ride in the rain. When it's not raining, the battery seems to hold its charge and the bike will happily start each morning. However, if I have ridden in the rain one day, the next day the battery is flat and the bike won't start. I can normally bump start it, but the other day I couldn't even do that.
Water getting in somewhere it shouldn't? Suggestions on where to look and what to do appreciated.
Old Jun 22, 2009 | 09:27 AM
Shadow's Avatar
Yup - def a short =
Steve-o got it again !
Old Jun 22, 2009 | 06:12 PM
Thanks for the replies, guys.
The lights seem to be working fine (maybe a bit dim considering there are twin globes). All other electrics work OK. How tragic is the horn on these bikes??
The only non-standard wiring is a trickle-charger wire connected to the battery so I can charge without pulling the saddle off etc. It looks OK, but I can remove it and see if it makes a difference.
I guess I'll just have to start pulling things off and look for water ingress.
Old Jun 22, 2009 | 06:17 PM
Sprock's Avatar
"The only non-standard wiring is a trickle-charger wire connected to the battery so I can charge without pulling the saddle off etc. It looks OK, but I can remove it and see if it makes a difference."
Have one of them myself wire tied to the rear peg.
Make sure the charge plug ain't gittin' soaked.....that'll knock that little acid box
on it's ***.
Old Jun 23, 2009 | 05:02 AM
I was thinking of replacing it with a pair of Fiaams: a bit more impressive. But I'll kick off with disconnecting it and see if that helps with the battery issue.
Thanks again.
Old Dec 28, 2012 | 04:14 PM
Putting this thread to bed (3 years later sigh...), and if anyone happens to read it: in the end the issue turned out to be nothing more mysterious than a dying stator - the battery was losing charge come rain or shine. I replaced the stator and all was good.
Old Dec 28, 2012 | 04:41 PM
TimBucTwo's Avatar
^ Glad to hear you finally got things sorted out.
Hope you get some good rides in...rain or shine. LOL
