battery dieing after 5 min ride
This bike is driving my father and I nuts. and we are about to just get rid of it.
The bike's battery died last year while riding so we changed the regulator and the battery (over 4 years old), still had the issue. We had the charging tested at two different shops and they said everything is fine with the charging.
One day I looked and saw the starter solenoid connector was burnt out. I figured maybe there is a short that caused this. Bought a new harness and solenoid, took it around the block on a fully charged battery. when I got back home the problem still persists,slow wind til stop.
I am stuck bc on a freshly charged battery, starts right up. Thinking we should just get rid of it. we spent so much money into it changing fork seals, new tires, brakes, spark plugs, valve adjustment, clean carbs, regulator, harness, battery, starter switch, solenoid, checking charging, stress test on the alternator.
My uncle thinks its the starter.
Any help please please please!!
Have you tracked back from the battery with a volt meter yet?
Does your R/R show signs of heat trauma? (melting or brownish connectors)
The first thing you need to do is test your charging system. The easiest way to do this is by using a digital multimeter with the setting set on AC Volts, start the bike and connect the meter to the battery, the meter should read between 13-15 volts AC. rev motor a little and watch meter to see if volts go up it should. If the volts rise then your charging system is functioning properly. If the volts are less than 12 volts then you may need to take the bike to a shop to have further testing done by a mechanic to see if it is the stator or regulator/rectifier.
Before you ask questions make sure we all know were you are, what year your bike is, model etc. That's a basic requirement unless you want wild guesses to console your frustration.
Go to your user CP and get your details sorted.
I'm sure this can be diagnosed, patience...patience.
Take a deep breath and start again.
I have a....... model..... year.....
Guest
Posts: n/a
First I would like to whack this into context for just one minute !! ...
Fork seals ....(std maintenance on ANY BIKE !!)
Tires .....(std periodic issue on ANY BIKE !!)
Brakes .....(std maintenance on ANY BIKE !!)
Spark plugs .....(std maintenance on ANY BIKE !!)
Valve adjustment .....(std service routine maintenance on ANY BIKE !!)
Clean carbs .....(Every bike owner goes there eventually )
Regulator..... (ok , a 100 buck repair )
Harness, .....(What did you pay for a used harness ?? 30 bucks ?? )
Battery .....(Every bike owner goes there too eventually )
Starter switch, solenoid .....( another 100 bucks or so ?? )
Ok , so you have already spent the cash as you put it ...
....SO why not just fix what ever it is now that is killing the starter ??? and get a great bike going properly so you can enjoy the dam thing !!
Having said that , hey , sell her not going?? for pennies?? .... that wont worry anyone here , but I am sure it will worry you and yu dad .. ??
but yer if you sell her , you can always buy a $5000(min) buck used bike that prolly will only need 90% of the expenditure that is mentioned above .... eventually they all cost some money to keep ....
just may be you should not bother with motorcycles as they can be rather expensive to keep on the road if you actually ride them regularly ???
I hope you stop whining and fix her :-)
Guest
Posts: n/a
Hey , you keep up all this voluntary and lets say very giving of you too offer , recycling.... and yu gunna need a second garage mate !!!! lol
Guest
Posts: n/a
Ok , yu want a title Tony .....yu got it mate
(once I clear it with someone that likes me in Admin , which may take a bitta time to find !! ???? lololol)
....."Crazy CBR Guy" it will be you CBR Salvage Good Samaritan you !!! lol
Hey as for my reply mate , I figure that anyone that decides to get half pissed ? (which you would have to be ? !!) to choose to trip into this section and do a face plant on our CBR1000F HOT barbeque !!! well they gotta expect to get a bloody bad burn mate !!! ***** !!
Hey , when yu carport is full , I will outta the goodness of my heart volunteer my shed space for any spare engines and such like !!!!
On second thoughts Tony , what about "Crazy CBR Salvage Guy"????
