Bar end removal?
Bar end removal?
Hey guys, hoping someone here has come accross this before and can offer some tips?
LH bar end - no problem, turn the bolt etc , end comes off nice and easy. RH bear end - unscrew the bolt....keep on unscrewing....etc etc nothing happens! It's nice and free but it isnt "undoing", just turning.
Must be a common thing i'd guess?
Cheers
Cheers
RE: Bar end removal?
if you can like honda 502 said pull up while you unscrew (i.e stick a flat head undre the head of the screw and unscrew it that way) if still no go you can depending how its set up screw it back as if your tighten it and cut the head of the bolt off when you have enough threds sticking out of the bottom (enough to grab with pliars) this way with the hex part of the bolt off you can unscrew it from the bottom if you get what i mean. And if its stripped like honda502 said and you get it out my way your ganna have to tap and dye it an 1/8' over size unless you want to buy new.
eekenterprises
01-19-2009 09:05 PM
