'91 1000f - Test results from alternator 6pin
Old 07-20-2018, 03:45 PM
thebeard's Avatar
Default '91 1000f - Test results from alternator 6pin
I've been having charging issues and it was first disguised by a melted r/r. Replaced that and everything was fine for a few weeks. Same problems, only the r/r tests good now. I checked the alternator 6p connector again st what the service manual says and here are my results:
  • All 3 yellow wires have continuity. (Book says to make sure they DON'T)
  • All 3 yellow wires read 0.4+ Ohm's (Book says 0-.1)
Now, before I go on the wild goose chase that is trying to find an alternator, is there anything I can do to rebuild/fix this sucker? I have a lathe, a mill and am pretty handy. Thanks for any info.
Old 07-23-2018, 10:29 AM
tentacleslap's Avatar
If it were me, I'd make a couple calls before taking it on. There's a couple shops in our town that specialize in rewinding alternators and starters, so would think repair is possible, but might be something left to a pro unless you're keen to learn how and not worried about messing it up
When you remove it make sure to leave the alternator shaft in place (ie don't just zap the three base bolts off) or else you'll be left with several bad options when it comes to reassembly
hmm
08-28-2013 07:21 AM
DevilInDisguise
07-06-2011 10:57 AM
ic2283
06-01-2010 11:54 AM
zrad
01-13-2007 04:43 PM
stephygee
Riding Gear
05-15-2006 11:57 AM
Quick Reply: '91 1000f - Test results from alternator 6pin
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
