87 Handle bar wieghts
Guest
Posts: n/a
The throttle side may require that you remove the rubber grip, so you can see the hole in the handlebar, under the grip, which holds the throttle assembly on the bar.
I'd just fit different bar ends with those rubber bits that expand as they tighten.
They should fit without any aggro as the shafts are shorter than the std bar ends.......
Do as Steve suggests to remove the bar inners.........
The inner weights are held in by internal retainer clips. To access them remove the rubber grip (clutch side) & throttle twist grip to expose the bare handle bar. I can't remember if there is one or two small holes each bar (I think two). The locking part of the retainer sits in these holes. Push the clip in (through the holes) whilst pulling the weight out through end of the handle bar. It's painful but saves breaking the retainers.
