1995 battery draining while bike sits off
Anyone else have thier batteries drain while the bike sits with no key in it?
I purchased a new rectifier and will install it, but what else should I check?? |
If you have a multimeter you can test for a parasitic draw. It’s very simple to do and there’s loads of examples of how to’s on you tube.
What symptoms did you have to think your r/r needed replacing ? |
Originally Posted by wes 17
(Post 1329023)
Had a similar mystery battery drain/not charging issue on a 95 I had. Couldn’t figure it out so after few trips to the mechanic and changing reg/rec, alternator and battery the issue turned out to be the stator according to mechanic. Apparently not an easy job but might help the diagnosis.
Originally Posted by cbroar
(Post 1329105)
where it's that located? |
Stator is behind left hand side Lower casing.
Best of luck mate. |
Stator is in the bit that broke= stator= stationary winding of wire.
Originally Posted by bonester
(Post 1329266)
Do you by any chance have a phone charger cord installed on your bike? Those often drain a small amount...even those without LED lights in them.
Originally Posted by pcmaher
(Post 1329290)
