| wolfman 1000 |
Sep 5, 2010 11:21 AM |
Hey like they say, anything is possible. Your main problems will be figuring out all the mounting points and sorting the rear seat subframe. then you gotta sort the clocks, cos they sure aint the same. you will need all the subframes from the rr and the seat subframe. Before you do that find a good friend with an rr and messure it with and without the bodywork on so you can work out if you will need to alter the body to fit round the frame. Best of luck and if you go for it take loads of pics while doing it and after cos it will be interesting to see. One question though.Why not just buy a rr and be done with it much easier.
