-   Aftermarket (https://cbrforum.com/forum/aftermarket-28/)
-   -   Power Commander Help??? (https://cbrforum.com/forum/aftermarket-28/power-commander-help-92655/)
mustardman3001 05-02-2009 12:38 AM
So I have determined the reason my bike wont start is because of something in the power commander, these are my bikes symptons
1. when i have the power commander all plugged in my fuel pump will not turn on and my bike will not run
2. When i unplug the power commander ground from the battery the fuel pump turns on and the bike will start, but second the ground touches the battery the bike dies instantly.
3. When i unplug the entire power commander system and plug all the stock connectors in the fuel pump turns on and the bike will start and run
I have noted that the power commander will not respond when i press on the faceplate buttons, but when i turn on the bike the display starts up as normal. I have also plugged the power commander into the computer and it is not sending any data back to the computer (such as throttle position, or RPM's).
Any suggestions, does anyone know if dynojet rebuilds powercommanders?
