LED Integrated Mirror CBR600F2
I bought LED integrated mirror for CBR600F2, and i wired them Green-Ground(-), Light Blue&Orange-the other(+).
I thought it worked first, but i wasnt paying attention on the indicator, and i just noticed that the indicator lamp was always on. And idk if this is normal, but both of the indicators are always on(just dont flush) which i dont mind. When i use turn signal switch, the turn signals both works. but then the indicator lamp turns off. Turn signals off - indicator turns on(dont flush), turn signals turns on(dont flush) Turn signals on - indicator turn off (on the side of the turn signal im using, and the other is on), turn signal flushes. Anybody any ideas? |
i found thread about LED and problem was solved by using diode(1N4001)
thanks |
yep, same as trucks or cars, LED's don't suck enough power for the solenoids to think they're workin, that's why alot of trucks you see converted to LED signals flash extra fast, as if the bulb was burnt out.
