Aftermarket Discuss aftermarket upgrades to your CBR here.
dual filament flush mount turn signals
Old Mar 2, 2007 | 06:23 PM
mikus_23's Avatar
Default dual filament flush mount turn signals
hey guys ive been looking alot on the internet to find some dual filament flush mount turn signals for my 02 f4i if anyone can help me out with some flush mounts that look good and are dual filament thanks alot......if anyone knows of any good sites to buy some frame sliders too i was looking at those rochocet bases and sliders those look really nice but not positive if i can get them for a 600 f4i let me know guys thanks
Old Mar 3, 2007 | 04:12 AM
dragonium25's Avatar
Default RE: dual filament flush mount turn signals
Why do you want dual filament for turn signals? Not even sure what that is...
Old Mar 3, 2007 | 11:00 AM
Dave K's Avatar
For the front of the bike. One element for turn signals one element for running lights.
Old Mar 3, 2007 | 10:46 PM
ORIGINAL: Dave K
That's not dual filament. Having a running light option for your turn signals is not about the bulb, it's the wiring. Most aftermarket turn signals are only 2-wired, whereas our bikes have an extra third wire for the running light. If this is what you're looking for, then do a search and you'll find a post where somebody used a diode and they got their turn signals to act as running lights as well.
In the case where a dual filament would be used is in the headlights where you want the same bulb to be your low beams as well as your high beams.
Old Mar 4, 2007 | 01:19 AM
Dave K's Avatar
I am sure I do not then understand your post or the original question. I have found most companies that produce turn signals make them both ways. I just installed a set on my bike from Lockart Phillips. Virtually every model of 2 wire light will also have acorresponding model with a 3 wire light from this company.Look in Chapparal (sp) or Dennis Kirk, etc. and you will see for yourself. Honda has been doing this on their street bike turn signals with running lightssince 1973. Maybe the words element and filament confused the answers. The nice part for me in doing this, is no resistor(with it's high temperature)was required, like is usually needed with using diode type lamps, or changing the flash stat to correspond with the change in resistance from diode to filament types of lamps.
Old Mar 4, 2007 | 05:56 PM
mikus_23's Avatar
so if i get any flush mount turn signals they will be both turn signals and running lights when i hook them up even if theres they come with just 2 wires
Old Mar 4, 2007 | 06:02 PM
Dave K's Avatar
No, you will only have either turn or running lights, depending which feed wire coming fromthe bikeyou use. Of the two wires on the new light, one will be the ground and the other will be for the bulb.
Old Mar 4, 2007 | 06:03 PM
mikus_23's Avatar
will 600rr flush mounts fit for a f4i cuase alot of internet sites only have parts for 600rr so im wondering if parts for 600rr will fit on 600f4i
Old Mar 19, 2007 | 02:27 PM
christhek's Avatar
Try PROTONS, they have both the wiring for turn signals and the running lights as well. I have them on my bike but haven't found others that do the same. Check indysuperbikes.com or supperbikesupply.com
Old Mar 22, 2007 | 05:33 PM
fishnride's Avatar
I'll second the Proton flush mounts. I have them on my 05 600RR and my wife had them on her 04 F4i before she got her 600RR. They are very visible and have a couple different flash patterns.
Manufacturer website:
www.hightechspeed.com
Angelo
Jan 23, 2012 11:56 PM
600CBRIDER
Dec 22, 2010 01:43 PM
dizzie56
Sep 9, 2007 01:47 AM
