900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
When do you replace the clutch?
Old Oct 7, 2007 | 09:53 AM
JonBrown's Avatar
Default When do you replace the clutch?
hey i was wondering at about what mileage should you replace the clutch on a 93 900? also what clutch would be best for it? a really nice high preformance one would be great
thanks
JonBrown
Old Oct 11, 2007 | 08:53 PM
onewheelneil's Avatar
Default RE: When do you replace the clutch?
when it is slipping. replace it with a honda clutch from ronayers.com or the dealer
Old Oct 17, 2007 | 01:51 AM
richhowerton's Avatar
A clutch will last a longtime depending on how you ride it. case in point I change out the clutch about 2-3K but I drag race the bike. I have a friend that i just changed his and he has 9K on it. so their is not a real answer their for miles. You will start to feel the clutch get soft feel to it, use the adj on it. If it is adj out and you start to feel soft then get the parts. Also a tell is sitting in gear with a warm bike rev it up to 10 K or so if the bike wants to learch on you it is time.
Old Oct 25, 2007 | 10:26 PM
JonBrown's Avatar
ORIGINAL: onewheelneil
see the prob is i dont really know if its slipping or not cause sometimes its slipping the other times the rear end is breaking loose.
thanks for the imput guys
JonBrown
Old Oct 28, 2007 | 05:29 PM
gixxereater's Avatar
My 900RR had 28K on the original when I sold the bike and my 1000 now has over 30k on the original with wheelies, track days, little drag racing (slow 60ft times) and commuting. They will go a VERY long time if dont wheelie with the clutch and/or drag race and get 1.70 60ft times.
Old Mar 16, 2008 | 11:24 AM
Jarrod Franklin's Avatar
take your clutch cover off and inspect it, measure the friction plate thickness, check your steel plates for warpage, check clutch basket for wear. service limits should be in your service manual, if everything checks out, you are good.
[align=left] [/align]
Old Apr 8, 2010 | 07:20 PM
speedextreme's Avatar
You can know if it is slipping by one way. Going somewhat slow, around 30mph. Put it in 2nd or 3rd gear. Then go wide open throttle instantly!!! If the RPM's spin up without increasing speed, then your clutch is slipping. And before any of you say that "your bike will spin the tire in 2nd gear with ease". PLEEZE get a life. I don't know of any one bike out there that will spin the tire in 2nd gear, that is rolling at 30mph and just going WOT with just a twist of the wrist and not clutching it.
And just to let you know. The Honda clutches are awesome. I have 47000+ miles on the OEM clutch! And I have clutched up many wheelies, done Friday night drags, and many trackdays.
Old Sep 19, 2010 | 05:44 PM
thedudeman's Avatar
I agree with others. Replace it when it starts to slip. I highly doubt your tire is breaking loose. Just gun it, like previous said in 2nd or 3rd.
It should be fairly obvious if its slipping or not. And if its "slipping some times, breaking the tire loose others" then its slipping. Slipping some of the time still equals slip, so its toast if true.
And I'd replace only with OEM. I've had trouble (albeit minor) with after-market clutches. Especially for street use.
Mr. B
Oct 15, 2010 12:59 AM
jurkey77
Jun 23, 2009 10:05 PM
lepto
May 30, 2009 07:27 PM
Nauree
Oct 2, 2008 08:57 AM
JonBrown
Oct 7, 2007 12:37 PM
