-   900 & + Modifications (https://cbrforum.com/forum/900-modifications-44/)
-   -   new gears ??? (https://cbrforum.com/forum/900-modifications-44/new-gears-45013/)
NOSTUPIDZONE Jul 18, 2007 10:04 PM
new gears ???
ordered -1 frt plus 3 rear how bad amd i gonna see the rpm at 70 mph
my chain i in good shape but shoud i go ahead and replace it or not
my dealer says thay can add a couple links if needed or should i get a new one to
be safe instead im at about half way in the wear range on this chain now
NOSTUPIDZONE Jul 21, 2007 11:22 PM
RE: new gears ???
think i will get a new chain anyway to feel better about it then i know for sure
chuckb Jul 22, 2007 09:30 PM
RE: new gears ???
i got a -1 +5 and it was an awesome bottom end gain.... but at 70mph you'r looking at almost 6K rpm. also make sure to do something about your speedo... mine is way off and the faster you're going the worse it is.....
1badeg Jul 24, 2007 02:32 PM
RE: new gears ???
ORIGINAL: chuckb
Yup, I did -1 front and +2 rear and my speedo's off by 10 mph at 90.....which put me at about 78-80 realistically. Definitely invest in a speedo healer.
Triax Jul 25, 2007 05:12 PM
RE: new gears ???
definately replace your chain I can't believe they told you to just add links. I did that to my F3 and I was sitting at 6-7k on the interstate or hwy.
chuckb Jul 25, 2007 08:28 PM
RE: new gears ???
how much does a speedo healer run for a 900rr??? and how do they work? i don't know **** about them???
NOSTUPIDZONE Jul 26, 2007 08:23 PM
RE: new gears ???
think ill wait til i need a new chain to install the rear sprocket
im gonna go ahead with the -1 up front as soon as i get it
NOSTUPIDZONE Jul 27, 2007 07:26 PM
RE: new gears ???
it is plus 2 rear not3 sorry
-1 frt +2 rear
NOSTUPIDZONE Aug 4, 2007 03:30 PM
RE: new gears ???
i have installed the -1 front and it really isnt very noticeable i was hoping for a bigger change
guess i need to go ahead install the rear and see what that does
