929 wiring
I've got a 2001 929 I got from a totaled bike and made a buggy.
The wiring is a problem.The switch went bad and I have some bad wiring from THE wreck!!!! Now I want a roll cage!:icon_fryingpan: Is the anyone that knows how I can use a toggle swich and bypass some things without affecting my fuel injection? Thanks!!!:icon_deadhorse: By the way I'm new and have built buggies before, but not like this one!!! |
Can you be more specific about what switch went bad and what you want to by pass with toggle switches?
You will need to get a diagram and sort it out for yourself. If you have specific questions about certain circuits, we can answer those. |
Igniton switch is bad. I've got the starter and fuel pump ,and the guages work.
The two wires that come off the switch is bypassed. The pink wire already has 12 volts. The servo motor and the injectors have no signal,and no power to the coils. can you help? |
