600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Single sided swingarm for F2
Old 11-17-2007 | 10:04 AM
paddysasausage's Avatar
Default Single sided swingarm for F2
what 1 would fit on my f2 thx for ur help ppl
Old 11-25-2007 | 12:01 PM
travsstuff's Avatar
Default RE: Single sided swing arm for cbr 600 f2
[sm=insomnia.gif].....may i suggest against this idea.......first off, if you could even find one, a single sided swingarm alone will be worth more than the bike, second, it will resquire fabrication of new bearing mounts, and possibly some modification to the frame.....the 'fad' of custom mounting SSL's to sportbikes really didnt come along until the early 2000's anyway, so its gonna be hella hard to find one that is even gonna be close to fitting an f2 as well..........just my two cents......
Old 11-25-2007 | 12:29 PM
rsp919's Avatar
CBRF 2009 AOTY !!
Well, I have to disagree. The "fad" has been around for some time. I had mine made in 1995. And, the NT650 is a close fit. all you have to do is weld two plates for a new shock mount. It's not that difficult to do. That's what I originaly had on mine then I decided to go with the N.W.S swingarm.
Old 11-25-2007 | 01:35 PM
travsstuff's Avatar
ORIGINAL: rsp919
i stand corrected, rsp does have one bad @ss bike
Old 12-08-2007 | 08:09 PM
VALKYIE's Avatar
The single sided swingarm that would fit your bike is a 1994 VFR 750. It is the swingarm I have on my F3 and the two frames are the same. So I suggest that you use that swingarm. I found mine on ebay including the rim, shock, brake caliper,and shock linkage for under 600.00 bucks. By the way I was thinking of making a kit including custom shock linkage, spacers, swingarm bearings and other parts needed for the modification. So let me know how that sounds to you.
Old 12-09-2007 | 03:34 AM
AzNBoI_585SF's Avatar
I got a stripped VFR750 SSSA ill sell for 100 bux mang let me know
Old 10-16-2012 | 09:19 PM
jbalber's Avatar
Default ill buy the swing arm let me know
do you still have it? im interested =D
Old 10-17-2012 | 01:04 AM
volcom440's Avatar
holy ****! this thread is 5 years old mang! lock this **** down someone...
grizzly
06-24-2013 12:13 PM
CBRme
02-14-2010 11:15 AM
vexednyht
10-14-2008 10:29 PM
TrIkKeDoUtF4I
04-19-2007 08:17 PM
