-   600 Modifications (https://cbrforum.com/forum/600-modifications-43/)
-   -   Race Tech fork springs fitment question (https://cbrforum.com/forum/600-modifications-43/race-tech-fork-springs-fitment-question-101302/)
mpz 09-24-2009 02:05 AM
Question for those who installed race tech fork springs. Did you need spring compressor to "shoehorn" Race Tech springs? I have just taken everything apart and noticed that their springs are 2 inches longer than stock. This (http://www.bayarearidersforum.com/fo...d.php?t=147565) awesome walk through doesn't mention it but the generic race tech instructions state you might need one depending on fork type and model. I'll be attempting to install them tomorrow on my 01 F4i so your prompt response is appreciated.
Thanks
mpz 09-24-2009 02:15 AM
Eh, I guess I should've posted this in "current models"...mods please move if possible
Follow up question since I'm posting, what fork oil did you go with? Anything specific that stands above the rest and complement Race Tech fork springs?
land_warrior.rus 09-25-2009 11:08 AM
Springs should be same lenght. If they are not you might have to cut the upper spacer shorter. Use whatever oil is spec in the manual, thing its 10W with OEM valving.
mpz 09-25-2009 11:16 AM
Called Race Tech to confirm and spring + spacer should be same length. I'm going with 10W per manual, will adjust if necessary after next track day.
