600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
f4/f4i fairing help
Old May 19, 2011 | 08:45 PM
nobr8ks's Avatar
Default f4/f4i fairing help
i did the front conversion to my f4 and changed it to the f4i setup. the ram air tubes are tight in there and i was wondering if anyone knew if the f4i closing plastics that attach to the gas tank and go to the front fairing would attach i dont want to order the parts and then find out they wont fit thanks in advance for any help
Old May 20, 2011 | 01:01 AM
cuetip's Avatar
I don't c y not, and where r pix of the swap BC I'm n the process of doing the same swap but not sure if the upper stay meaning the one that looks like a T would connect to the f4i fairing
Old May 20, 2011 | 05:22 AM
nobr8ks's Avatar
you need the f4i one and the gauges to make it look right
Old Aug 16, 2013 | 04:10 PM
chloeweb's Avatar
New Member
Hi guys! Did this swap work out? f4 from 1999 to a 2001 fairing?
kray923
Mar 17, 2009 10:11 AM
