600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
F3 front end conversion
Old Mar 1, 2012 | 12:59 PM
Criggs's Avatar
New Member
Cool F3 front end conversion
What's up forum? I have a 95 f3 and I want to put an inverted front for and tripple assembly on my bike. Is there a set up that bolts right up or one that someone has modified to fit?
Old Mar 6, 2012 | 03:06 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
might wanna look into the 954 inverted forks (or maybe its 929?)
Old Mar 8, 2012 | 11:54 AM
gotcbr's Avatar
The 600RR USD fork conversion would prob be the best option. You'll need the entire front end.
Keep in mind that your front end will be lower by at least an inch.
Steering/frame stops may not match up.
May have clearance issues w/ clip-ons & levers if you are going to use fairings.
Will change body position.
Will change handling...may need a steering damper b/c turn-in will be quicker.
Good luck w/ your project.
Old Apr 10, 2012 | 04:10 PM
95frankenF3's Avatar
i just bought the 954 front end for my 95... the bearing sizes are the same on paper... i'll post a thread when i get this thing done gotta get the cartridge bolt
Old Apr 24, 2012 | 11:12 AM
the 954 front end fits great... though turning all the way one direction likes to stop on the radiator, but only like 1/16 of an inch from the stop... seems like the bike sits a little lower but that mey be from mismatched settings and one of them being completely dry... you will have to route most of the wires and the clutch cable to whichever way works best, in the manual the clutch cable runs through the frame behind the steering head (how that works out i have no idea)... and you can use the same, caged ball bearings, that come out of the f3... but what i'm going to do is order a tapered roller bearing kit from allballs which is only $35 before shipping (which is also cheap), tnd TRs are a ton better anyways... added bonuses of the 954 front end, besides improved suspension, are the front brakes are better, rim has less spokes so it looks a little cleaner, and the inverted forks just plain look better (imo)
will look something like this...
Old May 12, 2012 | 06:23 AM
67msarge's Avatar
Default Forks
They look ALOT better!! Good job on the conversion! Where did you pick up the forks and Triple tree's? Are they the stock ones?
Old May 13, 2012 | 07:10 AM
there was a guy parting out an 02 954rr in Jacksonville, FL... i happened to come along at the right time... and yea they're stock
Old May 13, 2012 | 07:15 AM
67msarge's Avatar
Cool, maybe I could get lucky enough to find a complete set. I have to find out if they work on the f1's though. I thought somewhere on the forum someone had a link to a conversion chart somewhere?
Old May 14, 2012 | 10:11 PM
this might help...
Steering Stem Bearing Sizes list
Old Aug 10, 2012 | 02:03 AM
VALKYIE's Avatar
I know I am wrong for this because I changed my swingarm out and other parts. But why swap out the forks unless your are a hardcore rider or racer?
