Ern's take on the digital F4i upgrade
Finally got the guages mounted, after 2 weeks of sweltering in the
garage for 1-2 hours at a time. Here's my version of a mount-up. Gotcbr (i believe) turned me on to a site for buying the 9x connectors, so I didn't have to connect each one individually. So that part worked real well, too. Here's the final result.... http://a8.sphotos.ak.fbcdn.net/hphot..._5794416_n.jpg Ern |
Excellent work! That looks great. :icon_toast:
Glad the connectors worked out well for you. :) |
Wow that does really look great!!! Good work!
would you mind explaining how you made the mount for the gauges? I just bought my first bike (97 CBR f3) and am really considering this swap. I bought it at the END of the season, so I have to find some projects or else im going to try and hop on the bike with 3 feet of snow on the ground haha.
I don't like the open look, through the tripple trees, on a bike with a
fairing, so I wanted to keep the surround that the guages are mounted into intact. That kept the smooth flow of the guages into the rest of the fairing. It destroys the old guages. I took the cowl from the old one and cut the bezel/bump off to make the face flat. Took a plate of 1/4 aluminum and duplicated the F3 mount position/spacing. Epoxied the plate to the back of the cowl, then used bondo w/fiberglass to build a bead at the joining all the way around. then mounted the F4 guages in the position you see, on the plate. The mesh was just something I had laying around, to dress it up. OEM-Type Bullet & Spade Electrical Connectors for 1960's through 1970's Japanese Vehicles... Bridgestone, Datsun, Hodaka, Honda, Kawasaki, Landcruiser, Suzuki, Tohatsu, VW, & Yamaha That's where I got the matching connectors for the F4 guages. I soldered all the pins to the F3 harness, plugged the empty connector to the guages, and then using a diagram, plugged the harness pins into the corresponding place in the empty connector. For the clean factory look, I slipped a piece of heat-shrink around each of the 2 bundles and then cooked it down after all the pins were inserted properly. Ern |
how dose the digital speedo work? i dont get how you can go from a needle speedo, to a digital one..idk if im dumb or what lol is the speedo accurate? im doing this during down time, i just like to know how instead of why lol
The F3 uses a signal from the CDI for the guages instead of a mechanical cable off the
front wheel or output shaft to determine speed/rpm. So even though it displays in analog, it is actually a digital signal being processed. Ern |
well done.
when i did mine about 2 years ago i wanted to do a closed look, but at the time i was a pioneer myself haha. I made brackets i sold myself, and they turned out well. Sorry you missed out, they were perfect fit if i remember correctly. |
