600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
F3 - GSXR Caliper swap?
Old 09-14-2009, 10:32 AM
johnnyx's Avatar
Default F3 - GSXR Caliper swap?
Looking to swap out the F3 calipers for something bigger and more intimidating. Not really a performance issue. I can get a set of 07 GSXR calipers on the cheap, and I was wondering if mounting them would be an ordeal. Also, would I need to swap the master cylinder? Failing all that, are there any aftermarket ones out there?
Old 09-14-2009, 04:50 PM
cajunlowrida's Avatar
Those calipers are radial mount, so yes, the easiest thing would be to do a gixxer fork swap. I would recommend swapping to the radial master as well, although Im sure you could retain the stock one if willing to sacrifice some brake fade.
Old 09-15-2009, 09:34 AM
johnnyx's Avatar
Yeah; too much work, too expensive, screw it. Thanks.
Nuka
08-31-2012 12:44 PM
segraves1
09-22-2011 03:31 PM
newnut
07-22-2011 07:46 PM
jjennings153
04-07-2009 11:27 PM
noobF3er
08-15-2008 11:55 PM
Quick Reply: F3 - GSXR Caliper swap?
