Acewell on my f2
having trouble to get my acewell 3803 to work, the rpm wont work and i dont know what to do with the speedo :icon_doh:
i tried to hook up the rpm with the orginal rpm cable (green/ yellow?) but wont work. i dont know what the SPC-X.X RPM should be. please help me? best regards. |
try to tie into 1 of the coil leads, or strip some wire and rap it around a plug wire and conect that to the tach. where did u hook up the magnet and pickup for the speedo? i put the magnet in the rear rotor hole.
hi mark.
i did strip one of the coil wiering, and connected the rpm on it, its working ok, not 100%.. i did also buy a speedo conwerter, it goes on the org speedo plug at the wheel, and it conwert to electronic signals.. |
did u get instruction for the install? if not u can see or download them from the web site. just try the ground side of the coil for the tack. did u get a pick up sensor with it for the speedo ?
yes i have the useless manual :P
bought this one: Acewell - Acewell Accessories and Sensors - Speed Sensors - Cable Drive - ACE-S8 Screw in square drive adaptor | Digi dash | Digital Speedomter | Motorcycle Computer this is what the acwell guy said to me: You should connect to a wire that only goes to one coil. Not the one that splits You have 2 options. 1, use an ACE-S / ACE-G or ACE-S3 sensor and replace one of your disk bolts with a magnetic bolt. 2, use an ACE-S8 sensor to replace the speedo cable, but you would need to open up the ACE-3803, unsolder a wire, and resolder into a different location on the PCB - easy to do as long as you have a soldering iron. The soldering bit is easy... unsolder the green wire from the point on the PCB marked "speed" and resolder at the point marked "hall" |
so where r u now ? did u find the green wire and try it ?
the speedo works fine. and yes, i find the green wire.
only rpm that is working a bit odd, at high rpm its showing too little.. unstable.. at low rpm, until 4000, its fine. |
u should contact acewell about it and maybe get a replacement.
i am going through the same problem with a similar gauge i got from Danmoto, an ebay dealer from china. they sell a knock off of the acewell and others. my guage seems to be working fine on the speedo , but the tack is off. i am sending mine back for a refund. i found a member on another forum that has the Danmoto acewell knockoff that he is selling me for $75. i hope it works ? |
i dont really care about my unstable rpm numbers on high rpms.. now that my speedo is working im happy :)
i hope for u that acewell will work, if not, please contact me for help, i will help you the best i can :) |
I hope i dont need your help, but Thanks for the offer.
