1994 honda cbr 600 f2
Does any one out here or on here know if the fairings from a 98 fit a 94... I have seen on this forum that they might work. Frames are the same.
The fairing stay, the thing that holds your speedo and tach, and your upper fairning is mounted to is different. Also the taillight is different as far as rears go. If you mounting race fairing from F3 on to F2 you could make it work. But street fairings will have alignment flaws. Now if you switched to 98 fairing stay, speedo etc headlight so on and so forth, well yeh probably. But I doubt you want to do all that.
Thanks Frank was only curious sounds a bit too much....not cost too much work...lol
